INTERPRETACION DE ESCANEO VAG COM
Publicado: 23 Ago 2013 12:28
por Luismaux
Hola amigos, llevo tiempo leyendo por aquí y hace unos días se me encendieron dos luces amarillas de avería por ello me decidí a pasarle el vag com a mi coche, y una vez que le hice el escaneo me salieron los siguientes errores:
Address 01 -------------------------------------------------------
Controller: 038 906 019 KJ
Component: 1,9l R4 EDC 0000SG 5256
Coding: 00002
Shop #: WSC 06402
4 Faults Found:
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-10 - - - Intermittent
17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
P1549 - 35-00 - -
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Coding: 00043
Shop #: WSC 06402
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 822 D
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05124
Shop #: WSC 00000
VSSZZZ1MZ4R102853 SEZ7Z0D2451679
1 Fault Found:
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: AY Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 03665
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01359 - Internal Central Locking Switch: Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-00 - Implausible Signal
00930 - Locking Module for Central Locking: Rear Left (F222)
00931 - Locking Module for Central Locking: Rear Right (F223)
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 K
Component: Radio GRO 2 29
Coding: 00401
Shop #: WSC 06402
No fault code found.
End -------------------------------------------------------
Alguien me podría decir si estas averias son graves?
MUCHAS GRACIAS
Re: INTERPRETACION DE ESCANEO VAG COM
Publicado: 23 Ago 2013 23:44
por karlos2320
Por favor si no describes el año version y codigo motor de tu toledo no podemos ayudarte
Publicado: 24 Ago 2013 17:01
por Luismaux
karlos2320 escribió:Por favor si no describes el año version y codigo motor de tu toledo no podemos ayudarte
Tienes razón es un seat Toledo 1.9 TDI 130 CV SPORT del 2004
Publicado: 25 Ago 2013 00:50
Tiene toda la pinta de haberse quedado sin batería, guarda los errores los borras y vuelve a pasar el scan y verás como desaparecen todos o la mayoría.
Publicado: 25 Ago 2013 10:18
por Luismaux
jdaguilar escribió:Tiene toda la pinta de haberse quedado sin batería, guarda los errores los borras y vuelve a pasar el scan y verás como desaparecen todos o la mayoría.
Muchas gracias jdaguilar, puede ser porque últimamente fallaba un poco al arrancarlo, le volveré a pasar el vag com otra vez.
