Buenas tardes,me e comprado un vagcom el 12.12 le echo el test de los fallos se lo e pasado y me a tirado varios errores que nose como interpretarlo porque no me aparece a ver si alguien me ayuda , os paso el primero que lo guarde, paso el segundo tambien despues de borrar fallos y tras andar con el.
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06402
VCID: 5EB378F3DAC24EEEC6F-4A3A
1 Fault Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 3169F34FABDC81962BD-5072
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
VCID: 224B0C03AE3A2A0EA27-5000
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 D
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05122
Shop #: WSC 03474
VCID: 275D1D17C518CF26F59-5000
SEZ7Z0A1490048
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 E
Component: 2Y Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 06402
VCID: 3979CB6F23AC49D693D-49D8
Subsystem 1 - Part No: 1C1959801A
Component: 2Y Tõrsteuer.FS KLO 0006
Subsystem 2 - Part No: 1C1959802A
Component: 2Y Tõrsteuer.BF KLO 0006
2 Faults Found:
01179 - Incorrect Key Programming
35-00 - -
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
DESPUES DE BORRAR FALLOS Y ANDAR CON ÉL:
Coding: 00002
Shop #: WSC 06402
SEZ7Z0A1490048
1 Fault Found:
Readiness: N/A
Coding: 0001025
Coding: 12620
Shop #: WSC 06441
Coding: 05122
Shop #: WSC 03474
SEZ7Z0A1490048
Coding: 00006
Shop #: WSC 06402
VCID: F0EFB64BB056489EE43-5072
Coding: 00067
Shop #: WSC 06402
2 Faults Found:
35-00 - -
Tengo el coche reprogramado, cuando e borrado el fallo e andado con el noto el coche un poco más alegre,fui a echar gasoy se vino abajo... luego borré fallos y otra vez alegre, será que estaré aconstumbrado pero me comenta un amigo que huele un poco a gasoy pero nose si es por la reprogramacion ya que ningun tubo está picado,no moja el suelo ni nada, alternador tiene ni 1 año es nuevo aviso..
a ver si alguien me puede explicar esos errores,Muchas gracias!!
Fallos seat toledo mk2
- 4
- Versión y año de tu Toledo: Mk2 2002
- Been thanked: 4 times
Re: Fallos seat toledo mk2
Según esto, alternador mal, regulador mal o cableado mal.17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
Possible Causes
Alternator faulty
Voltage Regulator faulty
Wiring and/or connections faulty
Possible Solutions
Check / Replace Alternator
Check / Replace Voltage Regulator
Check wiring and connections
Check the fuse box that is in the battery tray, it might be burnt, the fuse or the complete plastic box (pretty common failure on Sharan because it carries so much electrical load). If so, change the complete fuse box, it is not too expensive fix if this is the cause.
Special Notes
When found on the BEW engine, check MVB 16, Field 1. In most cases values will be between 15% to 30% at idle. 0% could indicate a failed or incorrect alternator.
Algún mando no ha sido bien sincronizado.01179 - Incorrect Key Programming
Possible Symptoms
(One or more) Remote Control not working
Possible Causes
Remote Control Adaptation incomplete
Possible Solutions
Check Remote Control Adaptation
See Measuring Value Blocks (MVB)
Perform Remote Control Adaptation
Básicamente cableado mal o cerradura mal. Casi seguramente lo segundo, es típico.00928 - Locking Module for Central Locking; Front Driver Side (F220)
00928 - Locking Module for Central Locking; Front Driver Side (F220): Implausible Signal
Possible Symptoms
Door Locks not working properly
Possible Causes
Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220) faulty
Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220) faulty
Door Lock Mechanics are stiff/partially seized
Possible Solutions
Check Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220)
Check Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220)
Check Door Lock Mechanics/Operation
Check Locking Module for Central Locking; Front Driver Side (F220)
00928 - Locking Module for Central Locking; Front Driver Side (F220): Incorrectly Equipped
Possible Symptoms
Possible Causes
Incorrect Door Lock installed
Possible Solutions
Check Door Lock Part Number
Special Notes
NAR (North American Region) Models do NOT have a SAFE-Switch in their door locks, once these models are being wrongly equipped with a RoW (Rest of World) door lock, a SAFE feedback signal is being sent which causes this code.
- 4
jdaguilar escribió: ↑14 Feb 2020 20:25Según esto, alternador mal, regulador mal o cableado mal.17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
Possible Causes
Alternator faulty
Possible Solutions
Special Notes
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
Special Notes
exactamente fuera aparte estaba borrando mal los fallos ya todo solucionado gracias
